whenever i turn on the heat/defrost it smells like gas inside my car. Why is it doing that? how can i stop it?
Feb 23, 2008 at 5:53 AM
SUPERVIXEN024
MEMBER
I'm not entirely sure, but I have the same problem with my 98 Cavalier.
Last time I took it into a mechanic to get the O2 sensor fixed, the manager said he thought he smelled fuel, and said that it could be a leaky fuel injector; apparently Cavaliers are notorious for these?
Any help, experts? And how expensive is such a fix?
Feb 25, 2008 at 2:11 AM
MASTERTECHTIM
✓Experienced Mechanic
the 4 cyl engine is common for a leaking injector. i would also check the fuel lines to make sure one is not leaking.
Feb 25, 2008 at 2:13 AM
SUPERVIXEN024
MEMBER
Thanks for your reply...do you know about how much such a repair would cost?
