1997 Chevy Cavalier Fuel Injectors
214,105 MILES • 4 CYL • FWD • AUTOMATIC
DEON BROOKS I
I want to change leaking fuel injectors. I have 2 of 4 leaking. Should I change all 4?
I can not find how to do that on your website, can you help with the step by step instruction?
FYI, I use your site quite often. I LOVE IT! It's perfert for me, the "Yeah, I'll try it..." do-it-yourselfer.
Nov 5, 2008 at 4:22 AM
MMPRINCE4000
  • 8,548 POSTS
I would change all of them. You remove injector connectors, and fuel rail. Injectors pull out of head, be sure to change injector seals. A little lube (oil) on the seals will make them go in much easier.
Some injectors have small clips that hold them to rail, use a small screwdriver to rotate clip to unlock position to remove.
Nov 5, 2008 at 10:07 PM
