1997 Chevy Cavalier Fuel filter replacement
49,000 MILES • 4 CYL • FWD • AUTOMATIC
RICSHERM
I'm trying to remove the clip on the fuel line coming from the tank to the fuel filter. This car has been in salty winters so the clip is frozen and will not budge. I've soaked with WD40 many times. Even tho the fuel line is part of the $500.00 fuel pump, do you know of a replacement fuel line or a cheaper fix?
Mar 3, 2008 at 12:10 PM
SERVICE WRITER
  • 9,123 POSTS
Makes parts to repair the sending unit lines. They should be able to tell you who the local distributer is.
Mar 3, 2008 at 12:53 PM
