When I apply the brakes the front end shakes ?
14,900 MILES • 4 CYL • FWD • AUTOMATIC
SHOLSTROM01
When I apply the brakes the front end shakes but only when Im on like the highway. I just replaced all four brakes. What would be causing this?
Mar 17, 2008 at 10:18 AM
BMRFIXIT
  • 19,053 POSTS
you need to check the rotors install new one if you have not done that yet. Here is a guide that can help
https://www.2carpros.com/articles/steering-wheel-shakes-when-accelerating-or-braking
and
https://www.2carpros.com/articles/how-to-fix-a-car-with-shaky-steering-wheel-when-braking
Please go over these guides and report back.
Mar 17, 2008 at 10:25 AM
THE FACTORY MAN
  • 50 POSTS
Brake pulsation comes from rotor thickness variation. Thickness variation comes from a rotor that has run-out. Run-out comes from incorrect or uneven wheel nut torque, dirt/rust between the rotor/hub interface or a hub that has run-out. You first need to fix the cause of the run-out to prevent the repeat problem of brake pulsation. All GM dealers have a very specific TSB that address this issue and when the belletin is followed and the run-out measured and compensated for, the problem is fixed.
Mar 20, 2008 at 6:37 AM
RHALL77
  • 3,361 POSTS
BMRFIXIT is right replace the rotors, but also, clean the hub up good. Remove all rust if possible. This will help alot.
Mar 20, 2008 at 6:56 AM
