1997 Chevy Cavalier Feeling every road bump...
266,000 MILES • 4 CYL • 2WD • MANUAL
MUDPUPPY1756
  • 5 POSTS
I just had my front struts replaced because normal road bumps began to feel like driving over bad railroad tracks. While the ride is better, there is still a lot of road vibration being transmitted into the chassis and me. I've never had springs replaced, but I had the front control arms replaced at around 100,000 miles as well as tie rods and steering mechanisms. Any suggestion on what I should consider to reduce the vibration? I've also had the cushion in the driver's seat replaced once, about two to three years ago.
Oct 24, 2008 at 2:28 AM
RACEFAN966
  • 5,029 POSTS
Now when you had the struts replaced did you have the upper strut cushion-turn plate replaced? If not I would consider doing that. As for the front springs I would only replace them if one is broke or if the ride height is to low.
Oct 24, 2008 at 3:16 AM
