1997 Chevy Cavalier faulty sensor
PATRICK72
  • 1997 CHEVROLET CAVALIER
  • 4 CYL
  • 4WD
  • 130,000 MILES
Engine starts and runs ruff for over a minute then stalls and wont restart after several hours.
Saturday, April 26th, 2008 AT 4:49 AM
Check the fuel pressure with a fuel pressure gauge designed for your system and comeback with the readings this is where we start.
Saturday, April 26th, 2008 AT 5:06 AM
BMRFIXIT
  • 19,053 POSTS
Does it crank with no start?
Do u have a security light on or flashing?
If so separate ignition key from the key chain and the rest of key place in ignition and turn it on for 10 or so min
and then give it try
if not check fuel pressure
check for spark
if you have an alarm system make sure its disabled
Saturday, April 26th, 2008 AT 6:20 AM
Related Engine Not Running Content
