1997 Chevy Cavalier Exterior Door lock (Driver's Side)
KERNANDO
1997 Chevy Cavalier 4 cyl Front Wheel Drive Automatic 180km
Here is my door keylock cylinder on my car.
[img:2718674b78]http://www.2carpros.com/forum/automotive_pictures/438284_DSC00572_1.jpg[/img:2718674b78]
I'm looking for an easy, cheap way to make this car secure again is it possible?
Thank-You
I was thinking get a locksmith to cut a cylinder lock for my key then bondo? any other suggestions thanks!
Nov 21, 2009 at 3:47 PM
  • 110,246 POSTS
There is a large clip that holds it from the rear. Is the damage too large for it to hold? If so, cut a piece of sheet metal aprox 4" x 4". Drill a hole in it that the cylender can fit through. From inside the door, place the sheet metal that you cut then push the lock cylender through the door and sheet metal. Then when you replace the clip, it should hold everything in place for you.
Let me know if you have other questions. Also, if the lock cylender where the key goes is bad, you can get a new one at most parts stores. It will have a different key than the other door, but you will be able to lock your car.
Nov 24, 2009 at 1:59 PM
