1997 Chevy Cavalier Engine oil presure low
248,000 MILES • 4 CYL • FWD • MANUAL
DJOZSA
  • 9 POSTS
I have this cavalier, I just got the crank machined, and replaced all the lower bearings, including the conecting rod bearings and oil pump.
Put it together it started and ran intell I noticed the oil light on Ishut it down and checked oil presure which read 15 psi, what could be causing this low presure CAM BEARINGS? What runs the oil pump, its got a new timing chain also.
Please help and your effort will be rewarded!
Jul 9, 2010 at 11:41 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
Did you measure the bearing clearance to ensure that the specs are correct after having the crank ground, if the oil clearance is excessive the pressure will be affected drastically.
mark (mhpautos)
Jul 10, 2010 at 7:30 AM
DJOZSA
  • 9 POSTS
Sorry it took me so long to get back to you but I had to double check it with a different torque wrench.
The clearance I get is .002.
The specs I get from Mitchell on Demand is .0006-.0019 Inches,
The torque they want is 70 ft lbs on the mains,
Can't see no abnormal marks on the cam lobes? Oil is clean,oil pump seems to be operating, is there another way to check the cam without pulling it out? Or what else could it be.
Jul 18, 2010 at 5:13 AM
  • 31,937 POSTS
HI there,
Are you sure that the oil clearance is .002" as that is huge?
mark.
Jul 18, 2010 at 11:10 AM
DJOZSA
  • 9 POSTS
I just checked the clearance again, I think I used the wrong plastic gauge, this time I used the green plastic gauge and the reading looked better the reading is .0015 I think the red plastic gauge was too big that's why I had a poor reading.
Jul 19, 2010 at 11:02 AM
  • 31,937 POSTS
OK,
That is better, so we can eliminate crank oil bearing clearance, i would look at the pump and the oil pressure relief valve as well, cam bearings can cause a drop in oil pressure but they would have to be fairly flogged out for that drop, look at the pump and relief vale next.
mark, (mhpautos)
Jul 19, 2010 at 11:07 AM
DJOZSA
  • 9 POSTS
Sorry, I'm not quite sure what I should be looking for, the pump is new, I know sometimes that doesn't mean anything but I don't really know what to look for.
Is the oil presure reief valve located in the pump?
Jul 19, 2010 at 11:25 AM
  • 31,937 POSTS
Will have to check it out in Mitchell 1, will post soon
Mark
Jul 19, 2010 at 11:31 AM
  • 31,937 POSTS
I looks like it will be in the pump, things to check now, ensure that the mechanical gauge you are using is reading correctly and the low rearing is what it is, check oil pick up tube is not sucking air from a faulty gasket, was the crank oil galleries cleaned carefully of all swarf from the machining? replace oil filter as a precaution, are the lifters noisy, with such low pressure they may be rattling due to lack of supply.
mark (mhpautos)
Jul 19, 2010 at 11:38 AM
DJOZSA
  • 9 POSTS
On the oil pump there is no gasket, When starting and running the engine, it ran without no top end noise, at first yes intell the lifters got pumped up but ran ok afterwards, the main reason I wanted to check this problem out because of the oil light coming on, I changed the O.P.S. sensor with no luck, that's when I checked with a gauge still low, I ran the engine with no valve cover to see if the top was getting oil,not as much as it should.
This engine is still in the car, maybe not for long.
Jul 19, 2010 at 12:20 PM
  • 31,937 POSTS
OK, the only thing i may suggest is to run a good oil flush through the system, see if that flushes out any muck that may be causing a problem, if not you will have to start re checking the new pump, cam bearings, and all you have already done, this is all a bi strange indeed, it may be a simple as a faulty new pump!
mark (mhpautos)
Jul 19, 2010 at 12:30 PM
DJOZSA
  • 9 POSTS
Not only was the crank bearings bad but the entire cam with bearings are also shot, be carefull when you have a low oil presure reading,never just assume a flush will fix it, obviously the past owners never did proper oil changes just top it up, that's why it could be the most mind boggling,and the most fustrating problem to encounter.
Dec 21, 2010 at 4:54 PM
