1997 Chevy Cavalier Dome Light Blinks Off/On Continuously
1997 CHEVROLET CAVALIER
REESAH
Electrical problem
1997 Chevy Cavalier 4 cyl Two Wheel Drive Automatic
Recently, my dome light has started blinking off & on continuously. I thought it could be the bulb so, I checked it but, it's still good, although, the bulb is somewhat grey in color on one side. I then checked the fuse but, there's nothing wrong with it but, I went ahead & changed it anyway. The cars dome light usually stays on when you kill the engine until the key is removed. Then, stays on temporarily after you get out & close the door. If that info helps you any. If you need any further info just let me know. Btw, my windows & locks are not electric.
May 5, 2010 at 2:35 AM
MMPRINCE4000
  • 8,548 POSTS
Check the switch in the door jamb.
May 6, 2010 at 3:03 AM
