1997 Chevy Cavalier cooling system
THE WAY
Engine Cooling problem
1997 Chevy Cavalier 4 cyl Two Wheel Drive Automatic
I am having a problem with fluid disapering from my coolent tank . We put blue deval in the system becouse it was leaking from the head gasket . Now there is no signs of leaking but the fluid level goes empty every time i turn around .
Aug 30, 2010 at 3:04 AM
WRENCHTECH
  • 20,758 POSTS
You need to pressure test the cooling system first to be sure your leak isn't external. If not, then you could still have a head gasket problem that is burning the coolant through combustion chamber.
Aug 30, 2010 at 3:30 AM
