1997 Chevy Cavalier check engine light
QXR27
  • 1997 CHEVROLET CAVALIER
  • 4 CYL
  • FWD
  • 75,000 MILES
I have a '97 cavalier 2.2L. My check engine light came on so I took it to autozone for them to put it on the computer and they said it was the throttle position sensor and the EGR system. I dont see any performance problems though every website ive read says that you will see problems with the accelleration and shifting. Even though I dont see any performance problems do I still need to replace the sensor? If so is that somthing I would be able to do at home?
Friday, June 27th, 2008 AT 11:18 PM
OBXAUTOMEDIC
  • 3,711 POSTS
What were the codes? Letter and numbers ex: p0121.
Were the Codes Hard Codes or Pending Codes? With pending codes you may not notice any performance problems until it becomes a problem leaving you stuck somewere.
With the EGR Sysem check for Vacuum Leak.
You should be able to replace the TPS at home.
Sunday, June 29th, 2008 AT 1:56 PM
