1997 Chevy Cavalier air fuel mixture
139,000 MILES • 4 CYL • 2WD • AUTOMATIC
PEPSIMAN1957
ck eng light on code p1071 system lean 1 bank have replaced #2oyx sensor-pickup coil for 1and4bank and throttle position sensor and this code still kicks light on where do i go from here
Feb 27, 2010 at 8:37 AM
  • 31,937 POSTS
Hi there,
A lean mixture can indicate a vacuum leak in the induction system, often spraying a little starter fluid around the manifold while idling will pick up a leak, the revs will pick up when nit get a sniff of the starter fluid, but just a little as it is very volatile stuff.
mark (mhpautos)
Feb 27, 2010 at 8:58 AM
