Having trouble starting. New starter 3 years ago. Battery is good. Have to hit the ignitions sometimes 5-6 times before it will start. Couple times did not start at all. Can roll it, and sometimes will start.
2nd:Drivers side rear turn signal. Something going on there, works when I put a new bulb in for a little while, then stops. Notice a sort of "burn" or "melted" look to the bulbs when I change the bulb. Have cleaned out the socket several times with emery board, sometimes works, sometimes doesnt. Do I need a new socket? and can I use a universal one found in auto parts stores?
3Rd: AC stopped blowing cold air. Blows, but no cold air.. Could you help me please?
Thanks you
~Joslyn
Thanks you
~Joslyn
Jul 19, 2009 at 7:35 AM
