1997 Chevrolet Cavalier Z-24
MTB
1997 Chervrolet Cavalier Z-24
Mileage 122,000
Engine 2.4
The car has plenty of power, no smoke, no warning lights, does not overheat, but when you give it gas or rev the engine up, it makes a knocking noise. Checked the compression and each cylinder is well over 200. When you drive the car it makes the knocking noise through first and second but when it shifts into overdrive it quiets down alot. The car is an automatic. Where should I start?
No Check Engine light is on, After taking pan off, it seems that the chain at the oil pump is not real tight, All of the bearings look good, a little play in the crank but not much.
Jun 13, 2007 at 6:56 AM
E40WATER12
  • 522 POSTS
No check engine light on? Also, I would maybe see if youre oil pump isint working properly, Could have a knock sensor failing.
Jun 14, 2007 at 9:27 PM
XTREMEAUTOSPORT
timing chain could be going check that first before it costs alot of dough
Jun 15, 2007 at 7:54 AM
