i have put new water pump on this car and it still is leaking and gasket .runing out antifrze by bootom to bolts and the engin block.
Mar 8, 2008 at 10:21 AM
SERVICE WRITER
✓Experienced Mechanic
Definitly not a remanufactured one?
Your going to have to remove it and see what happened.
Be sure of the leak before you pull it that it is there.
I assume the bolts were torqued correctly and any bolts that had different lengths were put back in the right spot.
