1996 Chevy Cavalier water pump
NICK44
  • 1996 CHEVROLET CAVALIER
Engine Cooling problem
1996 Chevy Cavalier 4 cyl Two Wheel Drive Automatic 33k miles
how do you replace the water pump in a 1996 chevy cavalier?
Wednesday, February 3rd, 2010 AT 6:38 PM
1996 Chevrolet Cavalier L4-2.2L VIN 4
WATER PUMP
https://www.2carpros.com/forum/automotive_pictures/12900_wpc_1.gif
REMOVAL PROCEDURE
1.Negative battery cable.
2.Drain and recover the cooling system.
3.Loosen water pump. pulley bolts.
4.Drive belt.
5.Water pump. pulley attaching bolts, then remove the pulley.
6.Coolant surge tank hose.
7.Water pump attaching bolts, then remove the pump. Clean sealing surfaces completely.
INSTALLATION PROCEDURE
1.Using a new gasket, install the pump. Tighten bolts to25 Nm (18 ft. lbs.)
2.Water Pump Pulley to Pump. Tighten bolts to 30 Nm (22 ft. lbs.)
3.Drive belt.
4.Fill the cooling system. Refer to Bulletin No. 63-62-03.
5.Negative battery cable.
6.Inspect for leaks.
Wednesday, February 3rd, 2010 AT 6:47 PM
