1996 Chevy Cavalier turn signals
DD8700
  • 1996 CHEVROLET CAVALIER
Electrical problem
1996 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
where is the turn signal flasher unit located
Thursday, July 1st, 2010 AT 11:47 AM
RICHZOMBIE
  • 173 POSTS
To replace the turn signal switch, you have to pull the steering wheel to get the switch out from inside the steering column housing. Once the wheel is off, then you have to pull the lockplate, cam assembly, and a spring. The turn switch should come out easy, watch out for the wiring harness, though.
Thursday, July 1st, 2010 AT 11:57 AM
