1996 Chevy Cavalier Transmission is leaking on top of exhua
178,000 MILES • 4 CYL • FWD • AUTOMATIC
SDAVIS12S
I need to get a diagram of the transmission to find out which hose leading from the transmission is leaking next to the exhaust manafold. It has now been leaking worse since the other day. Please help me.
Jul 27, 2010 at 12:33 PM
  • 75,988 POSTS
It should be obvious which tranny cooler line is leaking it needs close order inspection
Jul 27, 2010 at 12:47 PM
SDAVIS12S
I need to print off a transmission diagram so I can locate which hose and reapir it. Can you steer me in the right direction so I can print off a diagram of the transmission.
Jul 27, 2010 at 2:16 PM
