1996 Chevy Cavalier transmission
187,000 MILES • 4 CYL • FWD • AUTOMATIC
CAVALIERZ24
ok when i drive and the car gets hot say 195 which is normal my transmission forgets or acts like it dont want to shift un less i bearly give it gas keep in mine only when car is warmed up i think i need a transmission fluid and filter change but i was told it was a 50 50 shot weather it would help or make things work seeing how it has a problem
Mar 20, 2009 at 6:03 PM
TURBOPLZ
  • 8 POSTS
If you've never done a flush and filter change, I would highly recommend it as you're way past due. It will help some, but the lack of maintenance on the transmission may have caused permanent failure.
Mar 25, 2009 at 11:28 PM
