1996 Chevy Cavalier only 2 cylinders are fifreing
PFCHEINTZY15
Engine Performance problem
1996 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
in my cavalier only two of my cylinders are fireing wich gives me no power. it is the two outside cylinders what can i do to fix this
Jan 20, 2010 at 3:34 AM
MATHIASO
  • 1,209 POSTS
Hello pfcheintzy15
The first step to fix the problem is to remove the 2 spark plugs.
If the plugs are fouled, check oil level.
The most likely cause is worn valve guide seals and/or guides, but worn rings and cylinders can also allow oil to enter the combustion chamber.
If spark plugs show heavy whitish to brown deposits,this may indicate a coolant leak
either past the head gasket or through a crack in the combustion chamber.
The last one is most like because of 2 adjacent cylinders.
Pressure test the cooling system to check for internal coolant leakage.
Jan 20, 2010 at 4:25 AM
PFCHEINTZY15
ive already replaced all plugs both o2 censors pretty much anything eltronical i have replaced checked oil level it was fine everything seemed to be in working order i also replaced the two coils and plug wires
Jan 20, 2010 at 6:40 AM
MATHIASO
  • 1,209 POSTS
If the problem still persist, have a compression test done in the two cylinders.
Jan 20, 2010 at 4:56 PM
