The car had been setting for 18 months , Had half a tank of gas . used it up and refilled tank , replace fuel filter and regulator , the pump comes on with key and turns off as normal when engine is started fuel pump gets increasingly louder until engine shut off . removed vent to tank tube from bottom of regulator . regulator was venting gas normal did not make differance , when engine shuts off , it will restart and run normal if you turn key to off an restart . if you dont turn it all the way off ,but just restart it will run erattic until it dies.
Oct 6, 2008 at 10:05 AM
