1996 Chevy Cavalier Noisy Engine - grind sound.
135,000 MILES • 4 CYL • 2WD • AUTOMATIC
JCURTS75
  • 12 POSTS
I had a really loud, almost grinding sound coming from engine area. The car was due for an oil change so I had it done about 2 weeks ago and the sound was less prevalent. Now it is back.
I have a certified mechanic friend who, 2 wks ago, said the oil might not be lubricating the engine as good as it used to, causing the slight shake and noises. He said I could add something to the car that would help with lubrication (but never found out what it was he was talking about).
I know the O2 sensor is bad, and was wondering what that will do over time? Could that add to the problem? Really any thoughts would be appreciated.
Aug 18, 2010 at 12:30 AM
MMPRINCE4000
  • 8,548 POSTS
Grinding is never a good noise, especially from engine, try some Lucas oil stabilizer in oil, if noise goes away, then most likely a bearing, oil pump.
Aug 18, 2010 at 12:50 AM
JCURTS75
  • 12 POSTS
do I just put that in where the oil goes? what's a bearing cost to replace (ballpark)?
Aug 18, 2010 at 12:52 AM
MMPRINCE4000
  • 8,548 POSTS
Substitute for 1 quart of oil. Check old oil for metal particles.
If main bearing is bad, it is cheaper to replace engine, as block could be damaged.
Aug 19, 2010 at 1:47 AM
