1996 Chevy Cavalier no power
1996 CHEVROLET CAVALIER
114,000 MILES • 4 CYL • FWD • AUTOMATIC
LRBAGGY88
when I am driving the car usually at higher speeds not always, the engine feels like there is not enough gas getting to cylinders. It causes hesitation in power like mini surges of power. There is no check engine light on. I recently had a tune-up to try to fix the problem and also one shop replaced the map sensor. I have tried fuel injector cleaner and I put a higher octane gas in but nothing seems to fix the problem. I need some expert advice. Please help unemployed female
May 4, 2009 at 10:22 AM
  • 110,244 POSTS
If you need to check fuel pressure from the pump. Here is a how to video to help.
http://www.2carpros.com/dia/test_fuel_pressure.htm
Let me know what you find. Also, when they tuned the car, did they replace the fuel filter?
May 5, 2009 at 5:28 AM
