1996 Chevy Cavalier new plugs and boots
DRAGOON6969
Engine Mechanical problem
1996 Chevy Cavalier 4 cyl Two Wheel Drive Automatic
Cavalier LS 2.4 replaced plugs and boots' engine will crank but won't start. checked the ignition module, it passed but still no start. There is what looks like a ground wire that runs under the module and contacts the block? could this come into play or do i need to look else where.
Mar 1, 2010 at 6:35 AM
JDL
  • 16,098 POSTS
Hi, my first thought, is to check for rpm signal. If you don't have a scanner, use a noid light on injector plug. Engine cranking, the noid light should flash.
Mar 1, 2010 at 8:03 AM
