1996 Chevy Cavalier need help
159,000 MILES • 4 CYL • FWD • AUTOMATIC
KARNIECLOWN
runs good before 50MPH but past 50 MPH the whole car starts to shake/wobble its also comes and goes im thinking a tie rod but im not sure
Mar 4, 2008 at 4:06 PM
BLACKOP555
  • 10,386 POSTS
first you should jack up the front end and wiggle the tire, if play is noted and no components of the front suspension are moving just the tire, then chances are its your wheel bearings, but if the inner tie rod or the tie rod starts shaking and moves with it then chances are its worn out and needs replacing.
Mar 23, 2008 at 12:16 PM
