1996 Chevy Cavalier lose signal on number 3 injector
FREYGUY04
Electrical problem
1996 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
I have been workin on this car for 2 weeks now engine is skipping we have changed head gasket coilpack and ignition module. has not fixed problem we test all 4 banks and its missing on #3 fuel injector. what else can cause this problem?
Sep 4, 2010 at 12:27 PM
MADMIKE1735
  • 951 POSTS
absolutely sure its the injector? or is it just a cyl 3 misfire??? if you narrowed it down to an injector, have you checked the harness with a noid light??? also, try testing the injector your self..... you can also try swapping the #3 injector with the #4 injector... im sure you have a code for a cyl 3 misfire, clear it... swap the injectors... if your misfire code comes up #4 then its that injector... replace it...
Sep 4, 2010 at 12:34 PM
FREYGUY04
we have swaped injectors i even got new one still nothing we are only getting signal to #3 injector once in while. didnt know if it could be computer problem
Sep 4, 2010 at 12:40 PM
MADMIKE1735
  • 951 POSTS
usually the injectors get their signal from the coilpacks.... have you checked compression in the # 3 cyl????
Sep 4, 2010 at 6:17 PM
FREYGUY04
thanks but figured it out broken off wire were the injector wire goes into the computer
Sep 5, 2010 at 11:45 AM
