1996 Chevy Cavalier Leaks Antifreeze
120,000 MILES • 4 CYL • FWD • MANUAL
96CAVZ24
Its kinda seems like it coming from the heater hoses from the housing of it. I first started smelling in through the vents and after i parked it was leaking. It has all the origanal hoses on it so i think ill start by replacing those. but i want to know what you all think it could be.
Feb 23, 2009 at 6:13 AM
MMPRINCE4000
  • 8,548 POSTS
Have system pressure tested to pinpoint leak. The smell of coolant inside is probably a leaking heater core.
While I would also replace the hoses, have the system pressure tested, and you will probably have to change heater core.
Feb 24, 2009 at 1:32 AM
