1996 Chevy Cavalier ignition wires
SMITHTAKA4N1
  • 1996 CHEVROLET CAVALIER
  • 4 CYL
  • FWD
  • MANUAL
  • 125,000 MILES
I replaced the heater core in my car now it wont stay running. I have one plug I cant figure out where it goes. There are 3 black wires coming out right behind the ignition with a plug on the end of it. I cant figure out where this goes or if it could be the problem.
Sunday, October 18th, 2009 AT 1:32 PM
Did you disconnect the battery when you replaced the heater core? If so the computer loses its memory and must go thru a computer relearning process- Or you can check and test the IACV
Sunday, October 18th, 2009 AT 2:05 PM
SMITHTAKA4N1
Yes I did disconnect the battery. How would the memory reset if the car wont stay running? It starts right up runs for about 2 seconds then dies. It will do this repeatedly. What is the IACV?
Monday, October 19th, 2009 AT 5:50 AM
The IACV its the( idle air control valve )maybe you might just want to clean it out and see what happens.
Monday, October 19th, 2009 AT 2:15 PM
