Yesterday began to start my car. I put the key in like normal all the lights and normal noises came on like normal...
However, there was one problem the key wouldnt turn in the ignition so i got my spare and tried it and that key wouldnt turn either .. Then in the process of turning wheel to try to turn the key the wheel locked.. I know prior to this ABS was lighting up and youj can hardly press the brake down as it now, but i dont know if that has anything to ldo with the ignition..
Also i went under the hood and tried to hot start it and the engine turned over but didnt start.....
Im thinking the problem is the ignition cylinder or something similiar but if it was te starter or selinoid the car wouldnt even crank under the hood when hotcranking engine..
angela
angela
Jun 15, 2008 at 8:18 PM
