1996 Chevy Cavalier IAC (Idle Air Control) Trouble
1996 CHEVROLET CAVALIER
71,000 MILES • 4 CYL • FWD • MANUAL
TAR65
We have had a scan done on this car It is a z24 and the scan says the IAC might be bad, vacuum leak , or dirty connection to the IAC. I have checked all of the above, also I have replaced the IAC, voltage checks out on the IAC fine.
The Check engine light keeps coming on, the car sputters/hesitates, when Idling if revved up quiclkly then released, the idle fluctuates, for about 10 seconds then drops to normal idle. The car idles at about 1100rpm.
Any sugestions on what to check now?
Aug 10, 2008 at 5:47 AM
RHALL77
  • 3,361 POSTS
what code are you getting
Aug 11, 2008 at 12:57 AM
TAR65
The trouble code taht we were told was being read was P0507.
Aug 12, 2008 at 3:34 PM
RHALL77
  • 3,361 POSTS
have you checked for a vacuum leak, is there any vacuum hoses pulled off
Aug 13, 2008 at 12:09 AM
