Car shut down following and dull sounding knock not metallic . found map sensor plug had fallen out. Tested spark plugs with spark gap tester found no spark Check all fuses and can hear fuel pump come on when trying to start. Could the pass lock 1 be holding out the spark and not the fuel pump??? What would be a go starting point to trouble shout. I do not have a code reader, and no way to get car to one. Can I trigger code flash some how?? PCM fuse was pulled and replaced a couple of times.
Feb 25, 2010 at 12:55 PM
