1996 Chevy Cavalier fuel pump relay
DHASTINGS
Electrical problem
1996 Chevy Cavalier Front Wheel Drive Manual 84000 miles
I am having an intermittent problem with the fuel pump not coming on. It seemed like if I would move around the wiring panel under the hood where the relay is, the fuel pump would finally come on. But sometimes it seems like if you just wait. It will magically come on by itself? I am not sure if it is related to a wiring problem or the security system.
My daughter spent 300.00 to have repaired sometime back. But the problem keeps happening and seems to happen more often now. Any suggestions or tips? Can you bypass the security system to rule that out?
Jun 13, 2008 at 1:15 AM
DOCFIXIT
  • 18,828 POSTS
Has a new fuel pump relay been installed? If your moving wires that go to the relay/fuse box see if terminals to relay fit good and tight.
Jun 13, 2008 at 2:50 AM
