1996 Chevy Cavalier Engine Start
133,300 MILES • 4 CYL • FWD • AUTOMATIC
BENNISHOGUN
My car wouldn't start. I could turn the key all the way as if starting the car, the lights and gauges all light up as if the car is going to start, however the engine doesn't even attempt to start. I had the switch replaced but still have the same lock and tumbler mechanism. This didn't fix the problem. In addition to this, attempting to bypass the lock and tumbler mechanism by just turning the switch with a screwdriver causes the car to start and then immediately die. Is the anti-theft device killing the car as a result of trying to bypass the lock and tumbler? Or is there a possibility that the lock and tumbler itself is bad, because when the entire switch assembly is together I can get the car to start occasionally using the key. It's intermittent but it does start now and then.
Nov 7, 2008 at 10:01 AM
JNOVACK
  • 723 POSTS
yes you will have to have the anti-theft system checked and possibly reprogramed
Nov 7, 2008 at 11:07 AM
