1996 Chevy Cavalier engine light
185,000 MILES • 4 CYL • FWD • AUTOMATIC
STBARST
What does sensor code p0141 mean? It says 02 heater circiut ( bank 1, sensor 2) on my code reader. How do I fix it? and is it easy to fix? Please help. Thank you.
Jun 5, 2008 at 3:42 AM
WILDFIREV9
  • 49 POSTS
A 96 Cavalier has 2 oxygen sensors, a single wire in the exhaust manifold and a 4 wire (heated) just after the catalytic converter.
Check the wiring to see if it is broken. Check for damage to the sensor itself.
Chances are the heater circuit in the sensor is bad.
With that many miles, replacing them wouldn't be a bad idea anyways. Also check all fuses.
What the heater does is preheats the sensor so it will tell the pcm to lean out the fuel mixture sooner for better efficiency.
Unfortunately, with a check engine lite on, you won't pass a smog test.
Hope I've been a help. If so, a vote of confidence would be nice.
Also, all donations no matter how small are gladly accepted. Keeps us going.
VIC
Jun 6, 2008 at 5:52 PM
