1996 Chevy Cavalier Drive
14,220 MILES • 4 CYL • 4WD • AUTOMATIC
BELLSSS
alll of a sudden my car will not take off in drive,"sometimes" It has no problem with reverse and will not go forward at times. Its just reving up not moving. it has never slipped or no problems what so ever. Do you have any idea where to start as what could be the problem. My husband an several machanics are stumped. He added transmission fluid thats it!!
Apr 7, 2009 at 11:23 AM
MMPRINCE4000
  • 8,548 POSTS
Check the shifter linkage, make sure it is not kinked or a bracket is loose. Move shifter (engine off) while someone looks at connection to trans. Make sure it is moving the full range.
If equipped with detent or kick down cable, check cable, it may be broke, or way out of adjustment.
Remove trans pan and change filter and add fluid to full.
If nothing above works, take to trans shop, some are offering free diagnosis, but generally when a trans starts slipping, it is due for rebuild.
You can also consider replacing trans with used one from salvage yard (especially if you are doing it yourself). The downside to this is that if replacement trans turns out to be bad, the salvage yard's warranty will only replace trans, not labor to replace.
Apr 8, 2009 at 2:07 AM
