Crankshaft position sensor
1996 CHEVROLET CAVALIER
145,000 MILES • 4 CYL • FWD • AUTOMATIC
CHEF6777
Where is the crankshaft position sensor located and are there any special tools required to remove. I was told it's on the back side of the engine but I see 4 different sensors back there, would it be the one that is lowest by the crank & oil pan?
Nov 17, 2008 at 10:07 PM
  • CERTIFIED EXPERT
Here is a guide to help walk you through the repair and diagrams below to show you the location and replacement below.
Nov 18, 2008 at 1:17 AM
BUDICE83
Where is and how do I replace the crankshaft sensor on a 2.2 liter Cevy Cavalier? I had the check engine light analized and it said that the #2 Cylynder was missfiring and that the cause was a bad crankshaft sensor. Please Help
E-mail me at scottbeaver@optonline.net
Thank You.
Sep 24, 2019 at 7:32 PM (Merged)
JNOVACK
  • CERTIFIED EXPERT
  • 723 POSTS
On your 1996 Chevrolet Cavalier 2.2L SFI OHV , the Crankshaft Position Sensor is located:
Under hood, passenger side, rear engine area, mounted on engine under intake manifold
KIRKMOODY
Can you show me a diagram of where the Crankshaft position sensor is located on a 1996 Chevy Cavalier LS Convertible 2.4 liter? Also how to replace it myself.
Thank you,
Kirk Moody
BLUELIGHTNIN6
  • CERTIFIED EXPERT
  • 16,542 POSTS
on front side of cylinder block
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_933.jpg
disconnect electrical connector and unbolt from mounting position to replace.
DAVETENNANT
put 96 engine in 97 car .crank sensors are different as well as icm. since i cannot locate 3-pin harness ,i must make my own. need wiring diagram for crank sensor for 96 cavalier 2.2
HMAC300
  • CERTIFIED EXPERT
  • 48,601 POSTS
it still ont' work because the crank sensor and wheel are 58x and you have 24x in your system. if you try to make it work you will have to replace with a different crank sensor and crankshaft to match
2CP-ARCHIVES
  • 4,540 POSTS
where is the location of the crankshaft sensor
  • CERTIFIED EXPERT
Sorry no picture location-
2.2L Crankshaft Position Sensor On right side of cylinder block, below coil.
2.3L Crankshaft Position Sensor On right side of cylinder block.
JIMMYMAY
Electrical problem
1995 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
where is the crank position sensor located
  • CERTIFIED EXPERT
  • 31,937 POSTS
Hi there. on the 2.3 litre....
https://www.2carpros.com/forum/automotive_pictures/61395_Noname_20.jpg
https://www.2carpros.com/forum/automotive_pictures/61395_Graphic_62.jpg
on the 2.2 litre....
https://www.2carpros.com/forum/automotive_pictures/61395_Noname1_12.jpg
https://www.2carpros.com/forum/automotive_pictures/61395_Graphic_1_9.jpg
Mark (mhpautos)
ROBERTWHIT
1989 Chevy Cavalier
where is the crank shaft sensor located on the 1989 cavalier
  • CERTIFIED EXPERT
Rear Of Engine.
https://www.2carpros.com/forum/automotive_pictures/12900_c_23.jpg
Lower RH Side Of Engine Applicable to: V6-189/3.1L
SUSAN05
1988 Chevy Cavalier
where is the crankshaft sensor located on a 1988 chevey cavalier
  • CERTIFIED EXPERT
See below
https://www.2carpros.com/forum/automotive_pictures/12900_cps_16.jpg
LARRYCRANE_2008
where is the crankshaft sensor on a 1989 chevy cavalier 2.8 fi ovh 6cyl,would it cause the car to stall out
JDL
  • CERTIFIED EXPERT
  • 16,098 POSTS
Hello, look on the backside of engine block, down low, you may have to get under the vehicle. The rpm signal comes from the crank sensor, if you lose the rpm signal going down the road, the vehicle dies. If the vehicle refuses to restart right-away, have a helper crank it, while you check for spark at the plugs and injector pulse.
