1996 Chevy Cavalier cooling fan won't work
243,442 MILES • 4 CYL • 2WD • AUTOMATIC
BLEIS
Hello,my cooling fan won't work, I change the cooling sensor, the fuse is ok, the relay is ok, I unplug the fan and test it on a 12v dc it's working good, when I test the wire by needle the wire I get negative on both wire that goes on the fan? I don't know what to do anymore, can someone help me? thank you.
May 14, 2009 at 1:23 PM
  • 75,988 POSTS
Fuses okay -Test the fan relay if okay could be that the computer is not energizing the relay due to a missing signal from the CTS or the engine temperature gauge switch.
May 14, 2009 at 1:42 PM
BLEIS
thank you for your fast answer
May 14, 2009 at 2:23 PM
