Hello, my cooling fan won't work, I change the cooling sensor, the fuse is ok, the relay is ok, I unplug the fan and test it on a 12v dc it's working good, when I test the wire by needle the wire I get negative on both wire that goes on the fan? I don't know what to do anymore, can someone help me? Thank you.
SPONSORED LINKS
Thursday, May 14th, 2009 AT 8:23 PM
