1996 Chevy Cavalier Clutch
1996 CHEVROLET CAVALIER
PHADEM
Transmission problem
1996 Chevy Cavalier 4 cyl Two Wheel Drive Manual
My 1996 Chevy Cavilier Z24 manual will start but it will not go into gear. I check the clutch fulid and it was empty so i filled it up. i pumped the clutch then check again it was no longer full so i put more in and pumped it a little more. then i left and came back about an hour later and all of the dot 3 fluid was leaking out of the bottom of the engine. What needs to be done
May 14, 2008 at 10:11 PM
  • 31,937 POSTS
Hi there,
If the fluid is leaking at the engine end of the system, you will have a faulty slave Cylinder, this will have to be replaced and the hydraulic system re bleed of air.
Mark (mhpautos)
May 14, 2008 at 11:33 PM
