since your car is a 1996 it could have an electrical speed sensor heres how to find out if you have one check under the dash and see if there is a cable running to your speedometer if not then you have an electrical speed sensor it should be located on the transmision tucked underneath the motor very close to the passenger side axle if the wires came off or are corroded then that would most likely be your problem if they aren't pulled off or corroded then the sensor itself is probably bad.
Feb 20, 2008 at 1:17 PM
