1996 Chevy Cavalier Brakes/electrical?
105,800 MILES • 6 CYL • FWD • AUTOMATIC
HERMAN105
When i am applying the brakes to my car above 20 mph but no higher than 30 mph, i hear a rather loud chirp/clicking noise. My headlights will also flicker with each chirp (usually about 4 to 5 times) as i brake.
I tried some brief troubleshooting by sticking my head out the window while braking and i couldnt here it coming directly form the tires, and it does sound more centered to the engine area. Now i think it could be alternator, but i am not too sure. Is it, or should it, be the alternator?
Mar 7, 2009 at 4:57 PM
MMPRINCE4000
  • 8,548 POSTS
Remove alt. and take it to any autoparts store and have it bench tested. Tester will measure output and if a bearing is bad you should hear it while testing.
Mar 11, 2009 at 1:23 AM
