Front or back rotors? If back rotors then make sure your parking brake is not engaged. If front then the only thing holds them on is the wheel assembly and the brake caliper so once they are removed the rotor can then slide off. Try hitting in the center in between each lug stud, thats the best way to do it.
SPONSORED LINKS
Monday, March 1st, 2010 AT 6:28 PM
