1996 Cavalier PCM
RPLOOF1084
i need to know where i can find the plugs that plug into the PCM mine are all messed up. but didnt know if there was replacment plugs or where to find them? i have a 1996 cavailer Z24 stardard transmission.
Apr 23, 2007 at 8:58 AM
CODYMAURER
  • 6 POSTS
i am not sure if you can get replacement connectors, and if you can, i am not sure where. What I would do is head to a local wrecker and get the connectors you need there. It should only cost a few dollars. Leave enough wire on the connectors to attach them to the wires in your car, and make sure you don't mess up any wires. I would reccommend doing one wire at a time, and use the wire's location on the connector as a reference
Apr 26, 2007 at 11:57 AM
