1995 Chevy Cavalier Timing belt
134,000 MILES • 4 CYL • FWD • AUTOMATIC
JESSYJ13
I think my timing belt has jumped. I have zero compression on all cylinders, valves and pistons both moving when engine cranked. Do I have to drop the motor to do this or is there another way? It is a 2.2 L.
Feb 21, 2010 at 5:18 AM
BLUELIGHTNIN6
  • 16,542 POSTS
should have timing chain not a belt. engine will have to be at least raised for the procedure because the oil pan will need removed, which requires loosening and lifting engine assembly.
Feb 21, 2010 at 3:18 PM
JESSYJ13
Thank you. I thought maybe the timing jumped, but with a chain probably not.
Feb 21, 2010 at 4:17 PM
