What are the steps to set everything up, IE when the #1 is at TDC what valves would have presure and what ones should Ths is a 2.2 liter and from the front I count valve from engine mount 1 2 3 4 5 6 7 8. I think the timing between the crank and cam are out. I have no compression what so ever on and cly. 1 2 3 4 nothing.
SPONSORED LINKS
Tuesday, May 27th, 2008 AT 11:41 PM
