1995 Chevy Cavalier timing?
178,000 MILES • 4 CYL • FWD • AUTOMATIC
ACTIONJACKSON77
Hi my car started losing power and has a choppy idle. It doesn't sound like skipping. I replaced the spark plugs which had a lot of oil around 2 of the plugs from a leaking valve cover gasket. That did not solve the problem still the same choppy idle.
Jan 22, 2009 at 10:22 AM
MMPRINCE4000
  • 8,548 POSTS
Sart by checking fuel pressure with a mechanical gauge. If low, then pump or clogged filter.
If presure is OK then check spark on each cylinder.
If spark is bad, the have ign. module checked at most autoparts stores for free.
Jan 23, 2009 at 12:00 AM
