1995 Chevy Cavalier The car has shifting problems
NINCK
  • 1995 CHEVROLET CAVALIER
  • 4 CYL
  • FWD
  • 181,000 MILES
I was driveing my car all day and it worked good and when I came up to a red light I stoped and when I went to take off the care went but at 49mph the rpm's was up high and it just wont shift. What could it be?
Monday, August 9th, 2010 AT 5:10 PM
MMPRINCE4000
  • 8,548 POSTS
Check the detent or "kickdown" cable from throttle body to trans, it may have broken.
It is also called "TV" throttle valve cable.
Tuesday, August 10th, 2010 AT 8:56 AM
NINCK
The kickdown cable is fine. The car can shift from P-R-N-D-2-1 its just wont shift the gears in Drive. But the only way I can get the speed up past 35 is by useing passing gear but even with that it max out at about 49mph. Could it b a sensor of some sort and if so how can I cheack it and see?
Tuesday, August 10th, 2010 AT 2:27 PM
MMPRINCE4000
  • 8,548 POSTS
I would start (if TV cable is OK) by changing the trans fluid and filter, look for any metal particles in drained fluid.
Could also be govenor, pump, torque convertor.
Wednesday, August 11th, 2010 AT 7:43 AM
