1995 Chevy Cavalier starting
171,000 MILES • 4 CYL • FWD • AUTOMATIC
TCAIN83
when i got into my car to start it one morning it smelt of burnt plastic or rubber. there are no burnt out fuses and everything works but when you try to start the car nothing happens. the battery is good and the altenator is good i recently changed the nuetral safety switch. the starter works but only if you kick start the starter solinoid . i don't know enough about ignition systems to know what the problem is but if there is anything anyone might be able to add it would be a huge help.
Jun 28, 2008 at 10:17 AM
JDL
  • 16,098 POSTS
I don't know if your ignition switch has ever been replaced, but, I saw an old recall, about the original switch being a fire hazzard, even with the key off.
I'd disconnect the positive battery cable, if you think the ignition switch might be the problem or if you have a fuse/relay center under the hood pull the 50A ign fuse.
If the ignition switch looks--feels--smells like it is melted anywhere, that's where I'd look. If your not sure what it looks like, some of the online parts stores have a picture. My info just says it's located at the bottom of the steering column. Where applicable, you may have to disarm the air bag, before you fool with anything.
If you think the problem is elsewhere, we can backtrack the wiring system,but, I wouldn't use ignition feed unless you can rule out the switch.
Jun 29, 2008 at 6:56 AM
