1995 Chevy Cavalier idle air control valve
156,000 MILES • 4 CYL • FWD • MANUAL
KURPAI_02
  • 5 POSTS
will a faulty iac cause poor gas mileage?
Jan 24, 2009 at 3:16 PM
BLUELIGHTNIN6
  • 16,542 POSTS
If you have faulty IAC your motor will idle badly. The revs will not stay at a constant level, even when your engine has reached operating temperature. If this is the case then of course the fuel mileage will be horrible as well. However, a faulty PCV valve will cause poor fuel mileage without bad idle. A stuck-open PCV valve will allow unmetered vacuum to cause a lean air/fuel mixture. The engine management system will "fatten-up" the fuel injection spray time (volume of fuel) to compensate for a lean air/fuel ration, thus using more fuel to accomplish the same task.
Thanks for using 2CarPros.com!
Jan 24, 2009 at 3:28 PM
