1995 Chevy Cavalier head gasket
JOEGIRGENTI
Engine Mechanical problem
1995 Chevy Cavalier 6 cyl Two Wheel Drive Automatic
Because of a coolant leak in the front of the engine, I was told the head gasket needed replacing. Shortly after the work was completed, i brought the car back to the repair shop because of it "shakeing". I was advised that the "head" is cracked and needed to be replaced. Is this coincidence that the head gasket and head needed to be replaced within six weeks of each other. Thank you for your reply!
Sep 29, 2008 at 12:12 PM
RHALL77
  • 3,361 POSTS
most likely it was the head to begin with. they should of checked it when it was off the vehicle
Sep 30, 2008 at 10:16 AM
